Taper outside with 3-D lines
NC7080
NC program for outside milling of a cone. The operation requires a linear path in the X/Z plane from bottom to top. At the program start you define all necessary parameters and the tool. From the entries, the control calculates the tool path and executes it. Among other things you define the pitch parameter. In it you specify the number of linear paths into which the control should divide the 360° arc.
