Reclining torus inside in contour lines
NC7030
NC program for inside machining of a reclining, torus-shaped (i.e. donut shaped) object. The machining operation is performed with a ball-nose cutter in contour lines so that the milling path runs in the X/Y plane and the infeed is in the X/Z plane.
TNC 640
TNC 620
iTNC 530
TNC 320
TNC 426/430
Objects
Milling
Milling in 3 axes (X, Y, Z)
Milling in 5 axes with turning function (X, Y, Z + tilting axes)
Milling in 3 + 2 axes (X, Y, Z + inclined axes)
NC program
Programming station
Programming station VirtualBox
Machine control
TNC7
