Mill a keyway into a shaft and deburr it with a forming tool
NC5105
NC program for milling a keyway into a shaft and subsequently deburring this slot at the upper edge with a forming tool.
A standard cycle is programmed for milling this slot. For calculating the tool path for deburring, an NC program is defined as cycle.
TNC 640 iTNC 530 TNC 620 TNC 320 NC program TNC7 Machine control Programming station Programming station VirtualBox Milling Deburring / chamfering Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes)
