Changing the feed rate step by step
NC8025
NC program for increasing or reducing the feed rate step by step. Over a defined distance the feed rate is changed step by step from an initial velocity to a final velocity. For this, the distance and the difference between the feed-rate values are divided by the pitch defined in a parameter. Then the feed rate is changed step by step by the determined value.
8025_en.H
TNC 310 TNC 640 TNC 155 TNC 410 TNC 355 TNC 426/430 TNC 407 iTNC 530 Milling in 3 axes (X, Y, Z) Calculations Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Drilling Milling NC program Programming station Programming station VirtualBox Machine control TNC7
