Touch probe not active
NC FAQ1088
The touch probe is not active after it has been inserted. Why not?
If the basic PLC program from HEIDENHAIN is used on your machine, then it suffices if in the PLC column of the TOOL.T tool table you set bit 0 (at far right) to 1.
If a different PLC program is used, then an M function might be necessary in order to activate the touch probe. Refer to your machine manual, or contact your machine manufacturer.
Machine control Manual input Program run Handwheel Measuring / probing FAQ iTNC 530 TNC 426/430
