Tapered feather key
NC3175
NC-Program for milling a body in the form of a tapered feather key. An end mill is used in contour lines. The number of contour lines and some more values you define in parameters. The body is machined from the bottom up. Therefore cycle 25 is used.
Milling
Milling in 3 axes (X, Y, Z)
Milling in 3 + 2 axes (X, Y, Z + inclined axes)
Milling in 5 axes (X, Y, Z + tilting axes)
Milling in 5 axes with turning function (X, Y, Z + tilting axes)
Objects
NC program
Programming station
Programming station VirtualBox
Machine control
TNC 640
TNC 620
iTNC 530
TNC 320
TNC 426/430
TNC7
