Taper inside with 3-D lines
NC7085
NC program for inside milling of a cone. The operation requires a linear path in the X/Z plane from top to bottom. At the program start you define all necessary parameters and the tool. From the entries, the control calculates the tool path and executes it. Among other things you define the pitch parameter. In it you specify the number of linear paths into which the control should divide the 360° arc.
NC program Machine control Programming station Programming station VirtualBox Milling Objects Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) TNC7 TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155
