Standing torus outside
NC7035
NC program for outside machining of a standing, torus-shaped object. The machining operation is performed with a ball-nose cutter with the milling path is in the Y/Z plane and the infeed is lateral in the X/Y plane.
TNC 640 TNC 426/430 iTNC 530 TNC 620 TNC 320 Milling in 3 axes (X, Y, Z) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Objects NC program Programming station Programming station VirtualBox Machine control Milling TNC7
