Standing torus inside
NC7040
NC program for inside machining of a standing, torus-shaped object. The machining operation is performed with a ball-nose cutter with the milling path is in the Y/Z plane and the infeed is lateral in the X/Y plane.
Objects Milling in 3 axes (X, Y, Z) Milling Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) NC program Machine control Programming station Programming station VirtualBox TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430
