Spiral point pattern with equal distances
NC1015
NC program for defining a spiral-shaped point pattern with equal position distances. All values required for calculating the pattern are to be defined in parameters. Based on these values, the control calculates the individual positions, approaches them and calls a machining cycle defined by you.
TNC 155 TNC 310 TNC 355 TNC 407 TNC 410 TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 Milling Machining positions Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control Drilling Milling in 3 axes (X, Y, Z) TNC7
