SL cycle with selectable contour
NC2145
NC-Program in which a SL cycle is definined. Its special feature is that you can use a Q parameter to select which subprogram number is to be used as a contour.
2145_en.h
Milling NC program Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) 2-D contours Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC7
