Running a 3+2-axis NC program on a pyramid fixture
NC4240
NC program for machining four workpieces using a pyramid fixture. The control mills a chamfer of 5 x 45 degrees on each of the workpieces (dimensions: 60 mm x 60 mm x 60 mm). The machining operation is carried out using an inclined end mill.
Video
4240_en.h
NC program Machine control Programming station Programming station VirtualBox Calculations Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling Inclined machining iTNC 530
