Resolving decimal values into binary values
NC8150
A machine parameter is read out and saved in Q1.
Q1 then contains a decimal value that is to be resolved into a binary value.
The corresponding bits are set in the BIT.tab table and can then be read out separately.
Supported by iTNC 530 from NC software no.: 34049x-04
iTNC 530 NC program Milling Calculations Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Programming station Programming station VirtualBox Machine control Tables
