Rectangular funnel, definition of all corners, with SL1 cycles
NC7090
NC program for machining a rectangular funnel and a pocket at the bottom. Definition of all eight corner points with the X and Y coordinates. The machining operation is performed in contour lines by using SL1 cycles to mill the entire surface.
The same application has also been implemented with SL2 cycles. See solution NC7095.
Milling Milling in 3 axes (X, Y, Z) Objects Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control iTNC 530 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310
