Reclining torus outside in contour lines
NC7025
NC program for outside machining of a reclining, torus-shaped (i.e. donut shaped) object. The machining operation is performed with a ball-nose cutter in contour lines so that the milling path runs in the X/Y plane and the infeed is in the X/Z plane.
TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 Objects Milling in 3 axes (X, Y, Z) Milling NC program Programming station Programming station VirtualBox Machine control TNC7
