Radius at edge of hole
NC3230
NC-Program for milling a radius at the edge of a hole. An end mill is used. The milling path is in a linearized circular path in the X/Z plane. You define the number of linear steps per quarter circle through a parameter. Likewise, you define how frequently this milling path is to be repeated in order to mill the radius all around.
Milling in 3 axes (X, Y, Z) Deburring / chamfering Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) Milling NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155 TNC7
