Radii in the XY plane
NC2080
NC program for milling arcs whose radius is larger than the maximum permissible radius in a path function. At the beginning of the program you define all required parameters. The control uses them to calculate the tool path. The path contour consists of individual linear movements. With the pitch parameter you define the number of linear blocks into which the control divides the arc. The control calculates the end points in the X and Y axis for each of these linear sections. Then it moves to them The control repeats the calculation and movement to the positions until it reaches the arc end point.
Milling Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155 TNC7
