Programming station causes error message from virus scanner
NC FAQ1056
After installing the programming station, the virus scanner reports error messages.
There is a system setting in Windows where you can grant access to selectable programs. Proceed as follows:
> Open the Windows Control Panel
> Select the system properties (System)
> Select the Advanced tab
> Click the Settings button in the Performance pane
> Select the Data Execution Prevention tab
> In order to grant specific access to the system, activate the “Turn on DEP for all programs and services except those I select” option
> Click the “Add” button
> Add the file plc.exe from the programming station directory sys\bin and confirm with OK.
Programming station FAQ TNC 640 TNC 620 iTNC 530 TNC 320
