Program OCM cycles
NC15000
The tutorial shows the programming of the OCM cycles. You can see the structure of the NC program. Here the workpiece contours are linked with a simple contour formula, and then Cycles 271 OCM CONTOUR DATAOCM CONTOUR DATA and 272 OCM ROUGHING are programmed. Subsequently, you can see the process in the Test Run mode.
