Polygon defined by the circumradius
NC2030
NC program for milling a polygon. You define the polygon by entering the circumradius and the number of corners. In addition, you set several parameters that define the polygon position and the machining operation. From these entries, the control calculates the required path contours and executes them.
2-D contours Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) Milling NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155 TNC7
