Polar pattern
Polar pattern
NC1110
NC program for defining a circular point pattern.  All values required for calculating the pattern are to be defined in parameters. Based on these values, the control calculates the individual positions, approaches them and calls a machining cycle defined by you. In this example, the machining cycle being called is a Cycle 12 performing a PGM call. The called program contains a path contour making holes by means of bore milling. You define the required parameters in the main program.
Drilling Milling in 3 axes (X, Y, Z) Milling Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) Machining positions NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155 TNC7
