P4C polygon as stud
P4C polygon as stud
NC2140
NC program for machining a stud with the contour of a P4C polygon profile according to DIN 32712. First you create a circular stud with Cycle 257. Then the surfaces are machined with Cycle 25. The geometric dimensions of P4C polygons according to DIN 32712 are provided in the table included in the program description.
2140_en.h
Milling in 3 axes (X, Y, Z) Milling Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC7
