P3G polygon as stud
P3G polygon as stud
NC2135
NC program for machining a stud with the contour of a P3G polygon profile according to DIN 32711. The control calculates the contour from the geometric dimensions you define. You can machine the contour with Cycle 25. The geometric dimensions of P3G polygons according to DIN 32711 are given in the table included in the program description.
2135_en.h
Milling in 3 axes (X, Y, Z) 2-D contours Milling Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 TNC 320 iTNC 530 TNC7
