No Control Panel in the taskbar
NC FAQ1122
When I start the programming station there is no icon for the Control Panel in the taskbar. This means that I can't show the virtual keyboard nor can I change the resolution.
In order to activate the TNC VBOX Control Panel you must start the programming station via the desktop icon of the programming station, and not from the Oracle VM VirtualBox Manager.
Then you can open the Control Panel from the Windows taskbar, where you can activate the virtual keyboard as well as set the window size and resolution of the programming station. You can also, for example, read the IP address of the programming station in order to establish a connection with TNCremo.
Programming station Programming station VirtualBox
