Multipass milling a concave radius on the workpiece edge
NC3225
Program for multipass milling of a concave radius on the workpiece edge. The machining operation can be executed with an end mill or a ball-nose cutter. The number of linear paths is defined with a parameter.
The workpiece edge to be machined is parallel to the X axis.
3225_en.h
Milling in 3 axes (X, Y, Z) Milling Deburring / chamfering Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC7
