Milling a circle with a C tilting table
NC FAQ1021
Frage:
Can a circular path be programmed with the table rotating, even if the part is not centered on the table?
Antwort:
Yes, it is possible if the M128/TCPM function is active. You program a polar circle CP with an incremental C rotation in the opposite direction.
Follow the link below to view a sample program from our NC Solutions database.
Link:
Milling chamfers
Machine control Programming station Programming Programming station VirtualBox FAQ TNC 640 TNC 620 iTNC 530 TNC 426/430 TNC7
