Milling a chamfer on a contour
NC3255
This NC program is for multipass-milling a chamfer on the upper edge of any contour. The control first machines the contour with Cycle 25. It then mills the chamfer in contour lines. Milling of the contour can be performed with an end mill, a ball-nose cutter, or a toroid cutter. For this purpose, the control reads the radius of the cutting edge from the tool table and calculates the corresponding tool path, without you needing to change anything in the NC program.
3255_en.H
NC program Milling in 5 axes (X, Y, Z + tilting axes) Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) Milling 2-D contours Deburring / chamfering Machine control Programming station Programming station VirtualBox TNC 640 TNC 620 TNC 320 TNC7
