Measuring and checking standard tolerances
NC8260
NC program for measuring and checking a standard tolerance in the uniform shaft and uniform hole systems to verify that the measurement result is within the tolerance.
The control then displays the status of the fit, the measurement result, and the tolerance dimensions in a window on the screen.
NC program Measuring / probing Tables Machine control TNC 640 TNC 620 TNC7
