“Lines on circular surface” point pattern
NC1025
NC program for defining a point pattern in which holes are made on a circular workpiece in linear arrangement (capacitor plate). The lines run in parallel to the X axis. In a parameter you define the distance of the holes in X direction. In the same way you define a factor specifying the distance of the lines in Y direction and further parameters that are required for the calculation. Based on these values, the control calculates all possible machining positions, approaches them and calls a drilling cycle defined by you. The control takes the tool radius into account when determining the position.
NC program Machine control Programming station Programming station VirtualBox Milling Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Drilling TNC 155 TNC 310 TNC 355 TNC 407 TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 Milling in 5 axes with turning function (X, Y, Z + tilting axes) TNC 410 TNC7
