Horizontal truncated cone, inside, with ball-nose cutter
NC7010
NC program for machining the inside of a truncated cone with a ball-nose cutter. The cone axis is parallel to the Y axis. The machining operation is performed in a circular arc around the center in the X and Z axes. The infeed is performed in the Y axis.
Milling in 3 axes (X, Y, Z) Objects Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155
