Horizontal truncated cone inside in contour lines
NC3045
NC-Program for machining a horizontal truncated cone from inside. The part is machined with a ball-nose cutter in contour lines.
The axis of rotation is parallel to the X axis.
3045_en.h
Milling Objects Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC7
