Horizontal cylinder, outside, in contour lines with ball-nose cutter
NC7050
NC program for machining the outside of a cylinder surface with a ball-nose cutter. The cylinder axis is parallel to the Y axis. The machining operation is performed in contour lines so that the milling path runs in the Y direction and the infeed is in the X and Z axes.
