Horizontal cylinder, inside, in contour lines with ball-nose cutter
NC7065
NC program for machining the inside of a cylinder surface with a ball-nose cutter. The cylinder axis is parallel to the Y axis. The machining operation is performed in contour lines so that the milling path runs in the Y direction and the infeed is in the X and Z axes.
Milling in 3 axes (X, Y, Z) Milling Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Programming station Programming station VirtualBox Machine control NC program Objects TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155 TNC7
