Hemisphere, outside, in contour lines with ball-nose cutter
NC7100
NC program for machining the outside of a hemisphere with a ball-nose cutter. The machining operation is performed in contour lines so that the milling path runs in the X/Y plane and the infeed is in the X/Z plane.
														Programming station
														Machine control
														Programming station VirtualBox
														Milling
														NC program
														Objects
														TNC 640
														TNC 620
														iTNC 530
														TNC 320
														TNC 426/430
														TNC 415/425
														TNC 410
														TNC 407
														TNC 355
														TNC 310
														TNC 155
														TNC7
