Hemisphere, outside, in 3-D lines with toroid cutter
NC7115
NC program for machining the outside of a hemisphere with a toroid cutter.
The milling operation is performed in an upward direction on an X/Z path. This movement is divided into individual linear paths. Then the coordinate system is rotated and the next path is machined. The specified pitch defines the accuracy and quality of the surface.
Milling in 3 axes (X, Y, Z) Objects Milling Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155 TNC7
