Hemisphere, outside, in 3-D lines with end mill
NC7110
NC program for machining the outside of a hemisphere with an end mill.
The milling operation is performed in an upward direction on an X/Z path. This movement is divided into individual linear paths. Then the coordinate system is rotated and the next path is machined. The specified pitch defines the accuracy and quality of the surface.
NC program Machine control Programming station Programming station VirtualBox Milling Objects TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155 TNC7
