Hemisphere, outside, as spiral path with toroid cutter
NC7125
NC program for machining the outside of a sphere section with a toroid cutter.
The machining operation is performed in a helical movement. This movement is divided into individual linear movements. The pitch defines the number of linear movements into which the path is divided, and thus influences the accuracy.
7125-en.h
TNC 640 iTNC 530 TNC 620 TNC 320 NC program Milling Programming station Programming station VirtualBox Machine control Objects Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) TNC 426/430 TNC 415/425 TNC 410 TNC7
