Hemisphere, outside, as spiral path with ball-nose cutter
NC7120
NC program for machining the outside of a sphere section with a ball-nose cutter.
The machining operation is performed in a helical movement. This movement is divided into individual linear movements. The pitch defines the number of linear movements into which the path is divided, and thus influences the accuracy.
7120-en.h
Milling Objects Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) Milling in 5 axes (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC7
