Frame point pattern
NC1105
Program for defining a frame-shaped point pattern. All values required for calculating the pattern are to be defined in parameters. Based on these values, the control calculates the individual positions, approaches them and calls a machining cycle defined by you.
Drilling
Milling in 3 axes (X, Y, Z)
Milling
Machining positions
Milling in 3 + 2 axes (X, Y, Z + inclined axes)
Milling in 5 axes (X, Y, Z + tilting axes)
Milling in 5 axes with turning function (X, Y, Z + tilting axes)
NC program
Programming station
Programming station VirtualBox
Machine control
TNC 640
TNC 620
iTNC 530
TNC 320
TNC 426/430
TNC 415/425
TNC 410
TNC 407
TNC 355
TNC 310
TNC 155
TNC7
