Feed rate is incorrect
NC FAQ1100
A feed rate smaller than what was programmed is displayed!
The feed rate shown always refers to the cutter’s center point path. During thread milling (circular motion) the programmed feed rate is in effect at the tool’s cutting edge, meaning that the feed rate displayed for the cutter’s center point path is proportionally lower, depending on the tool radius.
Program run Machine control FAQ TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC7 Milling
