Engraving of an order number and sequential piece number
NC9030
NC program with which you can engrave an eight-digit order or article number and the serial piece number on the workpiece. You define the fixed number in a table. Here you enter each digit of the number in a column. The control also saves the serial piece number in a table so that it does not get lost when power is switched off. You only need to reset this piece number to zero if you want to start a new series.
In the main program you have to define the tool and all parameters necessary for the two numbers. In the called programs you have to make changes only if you want to change the number of digits to be engraved
Program runs in the Test Run mode are also counted by the workpiece counter.
Milling Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) Engraving Tables NC program Programming station Programming station VirtualBox Machine control
