Ellipse in the XY plane
NC2070
NC program for milling an elliptical path. You enter all the required values in parameters. From the entries, the control calculates the required tool path and executes it. In this case, the tool path consists of the number of linear movements defined in the parameter.
2-D contours Milling in 3 axes (X, Y, Z) Milling Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155 TNC7
