Deburring a hole in the horizontal outside surface of a cylinder
NC5010
NC program for deburring a hole in the outside surface of a cylinder with a ball-nose cutter. The position of the hole, the radius of the hole and cylinder, as well as other settings can be made easily by parameter. The example program also shows the machining of the cylinder surface and the hole.
The cylinder axis must be parallel to the Y axis!
