Deburring a hole in the horizontal inside surface of a cylinder
NC5015
NC program for deburring a hole in the inside surface of a cylinder with a ball-nose cutter. The position of the hole, the radius of the hole and cylinder, as well as other settings can be made easily by parameter. The example program also shows the machining of the cylinder surface and the hole.
The cylinder axis must be parallel to the Y axis!
Milling Deburring / chamfering Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control
