Data transfer at the programming station
NC FAQ1053
Can TNCremo be used to transfer data from a programming station? Are special settings required?
To be able to establish a connection between HEIDENHAIN PC software (e.g. TNCremo or CycleDesign) and the programming station, the programming station has a special IP address, called the "loop-back IP". This loop-back IP is 127.0.0.1 and it is entered automatically if you select the "Local" connection in the configuration. Then you can establish a connection with the programming station as if you were connected with a machine.
