Create log from an NC program run
NC8175
NC- program for generating a log file from the program. In the example, at program start the control writes the current date, time aud program name including path to the log. At program end the control calculates the program run time from the system time and also enters it in the log. In the mask file , you specify which entries you would like to write to the log so that you can adapt the log to your requirements.
TNC 640 iTNC 530 TNC 620 TNC 320 Milling Milling-turning Calculations Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control TNC7
