Connecting a printer to a TNC
NC FAQ1038
The manual describes how to output directly to a printer via the RS232 interface using the FN 16 Data function. Unfortunately, it does not say what type of printer is necessary nor what type of cable is needed. I have already tried a matrix printer and an inkjet printer from HP, and always receive the message “Ext. data in-/output not ready”. I also tried connecting it to the operating panel and in the electrical cabinet (X21), but always with the same result.
If you want to run a printer via RS 232 (V24), you must use a serial printer. However, these printers have become pretty rare. You should connect the printer using a serial interface cable (ID 274545).
Another possibility, if your control is equipped with an Ethernet card, would be to use a network printer. A normal printer cannot be used since printer drivers cannot be installed on the control.
Data transfer Machine control FAQ TNC 640 TNC 620 iTNC 530 TNC 320 TNC 128 TNC 426/430
