Concave arc segment
NC3085
NC program for machining a concave arc segment. You define the angular lengths of the segment in the X/Y plane and the X/Z plane using parameters. In addition, the radius to be machined in the X/Z plane can be defined at the start of the contour and at the end of the contour. The control calculates the tool path from the parameters you have defined and machines the contour.
