Circular pocket with radius on pocket floor
NC2150
NC-Program for manufacturing a circular pocket in which the pocket floor and lateral surface are rounded together. It is machined with a toroid cutter. The machining is done in three steps. First the pocked is milled in two differend depths and after that the radius is milled.
2150_en.H
NC program Milling Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) 2-D contours Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC7
