“CC” and “PGM CALL” keys not available
NC FAQ1067
Problem with programming station: CC, PGM CALL and TOOL CALL keys don’t work.
The problem arises from an overlap in the assignments for keystroke shortcuts between the programming station and the “Intel® Extreme Graphics 2” or “ATI RADEON XPRESS 200 series” on-board graphics card in your PC.
You can fix this problem with the following procedure:
> Control Panel
> Open Intel(®) Extreme Graphics (or ATI Catalyst® Control Center)
> Select the graphics properties
> Select the Hotkeys tab
> Deactivate hotkeys
There might also be keystroke shortcuts in other applications causing this same problem.
